The Samsung Captivate is a USA-exclusive flagship Android phone in the Galaxy S class of devices, released by Samsung in March 2010 for use on the AT&T network. Identifiable by model number SGH-I897.
13 Questions View all
Question Closed
How do I replace my samsung captivate charge port?
I'm willing to send, my phone off for someone to fix my phone, or suggestions to businesses that know how. I took the phone completely apart, and then realized it was a soldering job. Please help!
Add a comment
Most Helpful Answer
It is possible to repair the problem, but with how dense a MicroUSB port is it won't be easy. What you need to do is take the phone apart and remove the motherboard to get to the port. You can see howw here.
Once the phone is apart you'll need a good soldering iron or rework station. You aren't going to able to use the cheapest iron you can get for this repair.
If you use a soldering iron what you want to do is put some flux on the connector and put the braid on the pins. Once you think you have it off just enough lift the wick up while keeping the soldering iron on it. See if you got rid of all the solder. If not, rinse and repeat
Once you do that, go to the ground clips and desolder those the same way. Once you remove all four lift the old connector off.
Once you get it off, take your replacement connector and put it on the board. Then you want to solder the ground pins in to keep it intact and in the same place. After soldering the grounds in, put some solder on the tip of the iron and push down. Do not use a lot of solder. Do this for all of the pins on the new connector. Once this is done verify there are no shorts. If there are, fix them before powering up the phone and charging it.
If you did this correctly you should have a working phone. If you have a hot air station, just mask off the board and remove it that way. It's also a lot easier too.
Score 2
1 Comment:
Do you think I could send the port and mother board to you, and trust you to send it back?
by
Add a comment
It is difficult for me. I have a Captivate i897 and the port is dead. I have the new port sitting here and I have two different soldering irons. My heavy duty iron will not get hot enough to melt the solder. I am using desoldering braid as well. I had no luck, so I am in the market for a new motherboard but those are impossible to find. now I am trying to buy a cheap i897. I really love these phones. *I know this thread is over a year old. Did you ever get the phone fixed?
Score 1
1 Comment:
Lisa Gibson, try to put some solder on your soldering tip before you try to unsolder with soldering braid. Also, dip the braid in flux.
by
Add a comment
-Abrokencellphone.weebly.com 385-202-5886. located in salt lake city. ask for handy andy or cell phone charlie the best in the business! they fixed mine for cheat 50.00 dollars! or theyll sell you the part 3.00 dollars plus s.h. (micro usb sharging port.)!!
1 Comment:
This guy knows what he is doing and very trustworthy and cheap
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 6,946
