Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 Questions View all
Trying to upgrade iMac A1312
Hi there,
I have a 2011 iMac A1312. I am looking to upgrade its processor to something a more powerful. I am also looking to upgrade its GPU since its suffered GPU failure twice. What would be the best processor and GPU for it and how would I install it? Is there also a way to get macOS Mojave on it? I haven't powered it on in 13 years so I am not fully sure of its condition
Thanks for your help!
Add a comment
1 Answer
Chosen Solution
Sadly your options are limited to what Apple used in this series 2011 27” iMacs depending on what you currently have there might not be an option or not enough of an improvement. As an example jumping between the i5 to i7 only gets you a bit more multi-core performance which depending on the Apps you’re using won’t be very noticeable.
For most maxing the RAM and installing. SSD drive as the boot drive holding your Apps and having a fair amount of free space so the system has some elbow room for virtual RAM, caching and some apps use scratch space. A smaller SSD (less than a TB) should have 1/3 free and a larger 1/4 will do.
As far as Graphics again your options are limited! This series uses a MXM board which is no longer being made and Apples OS drivers only support what they used at best a newer version of the board will use compatibility mode so you don’t get all of the benefits the newer Gen boards offer and to this the cooling rig needs to fit the board and Apples boards also have custom firmware which needs alteration to work correctly.
Score 1
Add a comment
Add your answer
Z S will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 89
