Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
My MacBook not powering on while charger shows green light
I have a MacBook Pro retina display from 2015.
It was working till last week when it suddenly went blank. I tried to reboot but nothing happened. I tried rebooting after couple of days, it did power on once and allowed me to login but went black again
Since then I have not been able to login, The charger went from amber to green over certain time, that to me indicates the battery is still good.
1 Comment:
Do you hear the fan spinning when you try to turn the laptop on?
by
Add a comment
1 Answer
Give the age of the system I’m suspecting you battery has failed. While the MagSafe connector is showing a Green LED as well as showing the discharge state it can lie!
Give this a try, follow the first 6 Steps in this guide MacBook Pro 13" Retina Display Mid 2014 Battery Replacement
Then with nothing connected, press and hold the power button a good 15secs to fully discharge the logic board. Now plug in the MagSafe charger the system should spontaneously startup, let it fully boot up and do a proper shutdown.
Reconnect the battery and restart again with the charger plugged in. Now quickly download CoconutBattery and take a snapshot of the apps main window with the battery tab opened and post it here for us to see.
Add a comment
Add your answer
4 insta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 21
