Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211 Questions View all
No power after screen replacement. Please help me find this part!
I replaced the screen on a 16” 2019 model, and the last thing I had to do was connect the battery cable to the (7 pin ribbon cable connection on the logic board I believe) and the “pressure” clip broke off so I think that might be the problem. No connection? Where can I find this replacement part?
UPDATE:
Had a buddy microsolder a new one on, and it booted for one second then shut off and now no response. Any ideas? Could it be a bad connection? Or did we just fry the logic board?
Add a comment
You don’t need to replace the full connector, just the latch part. I would try to find it as it can be put back as it’s not uncommon to snap off.
Add a comment
cole Wengender the connector is a Fujikura/DDK FF14A-6C-R11DL-B-3H. You can get it on some places as a single item, others require you to buy at least 10. Do an online search with that number and see what will work for you. Then get yourself a few of those and gently lever one side, then the next side of the lock out of the connector. Transplant that lock to your connector.
Add a comment
Add your answer
cole Wengender will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 94
