Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Questions View all
The headphone jack isn't working properly
The headphone jack only allows the right earphone to work. I can jiggle the connector and it breaks up. How do I fix it? It doesn't matter if I change to different headphones... it still does the same thing.
Score -1
Add a comment
Chosen Solution
Check to see if you have broken a tip off any of your headsets. It may be in the iPod and preventing full contact.
Score 2
Add a comment
This means that the headphone jack is becoming faulty and needs to be replaced. Simply locate the size of your iPod video and replace the headphone jack/hold switch. Very easy to do.
1 Comment:
What's the reason for the downvote? Sure, you should check the headphones out first. But this is a solid response.
by
Add a comment
Add your answer
SuzV will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 9
All Time: 1,044
