2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
White MacBook water damaged,is it fixable?
So my MacBook 2010 13” got water damaged 8 years ago in 2015,and i want to fix it,but only if i can recover the HDD
here is where the water hit
İ know it will be worth it as this was my favorite most valuable Mac i have ever owned
İm just asking if its fixable and which parts could have been damaged
Update 1:İ still havent fixed it as i had to deal with my car related problems but now i think i will fix another computer of the same model and see what works like that
İm planning on switching to this completely
Score 1
Add a comment
1 Answer
Chosen Solution
Hi
If it’s the data your after there is a chance that the hdd might not be affected but I cannot confirm that
If you remove the hdd and use a adapter you can check out some of the data if it’s survived
Also if you fully disassemble the machine using this guide
MacBook Unibody Model A1342 Upper Case Replacement
you might be able to see everything that’s been effected and it could be fixable by cleaning the damaged with isopropyl alcohol However in most cases it usually needs professional reworking
Hopefully this helps
Any questions please ask
Score 3
4 Comments:
İ think it does need a professional touch,but i know a professional,so no problem with that
İ remember the water was spilled exactly between F5 and F6
The reason i think it needs a professional touch is because i took it apart to see if the fans spun for even a milisecond and no signs of life exist
Might be because it hasnt been charged fully since it died,might have caused a short circuit because i tried turning it on right after i spilled water on it
But i do think it is fixable
by
İ hope i do get this working though,its my favorite laptop ever
İt was 8 years since the incident,and i still wish i was careful
by
@kaancan
Best of luck with it,I would get it seen to by a professional if your unsure,I can’t guarantee anything but your data could be fine as the hdd sits beside the trackpad…fingers crossed:-)
by
i have officially fixed the MacBook
by
Add a comment
Add your answer
KAAN CAN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 57
