The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
25 Questions View all
Replace airport card/modem in TC gen 4 (802.11N)
Can I replace the Airport Card/Module in the Airport Time Capsule A1409 4th gen (802.11N)?
I fear the answer is Duh, NO!, but the answer is always no if you don't ask.
Thanks, Mark
PS: Is it worth replacing the HD with a SSD?
Add a comment
1 Answer
Chosen Solution
While you can’t alter the capsules WiFi interface, you can still connect a WiFI unit externally! As far as swapping out the HDD to a SSD while that can be done, you won’t get the best performance as this units SATA interface is only SATA II not SATA III
So consider your needs, review your cost Vs benefits.
1 Comment:
Thank you. Cost is a biggie, but having pieces parts lying around, had to ask those with more experience, skills and knowledge than me.
It works well, as a basic backup, but occasionally I get the Tim "The Toolman" Taylor moments, and want to make it faster, better just because it's (sometimes) possible. ; )
by
Add a comment
Add your answer
mark ray will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 55
