Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Questions View all
Kernel take about 90% from CPU
Good Day,
Im have problems, with Imac EMC2544, that Fan speed and very slow to do anything,
when I checked the Active Montier I saw the Kernel take about 90% from CPU , so I did clean install , it takes more than 14 hour to finished and the mouse moves so slow and it sometimes stop moving.
Thanks
Add a comment
1 Answer
Most Helpful Answer
This behavior is pretty indicative of either an issue with overheating, or one of the sensors. Kernel task, if that’s what you’re referencing is a process responsible for many things, and one is sucking up CPU cycles from other processes that the device thinks may cause issues with heat, or stress the system.
This is also normal behavior if the Mac thinks one of its sensors is missing, or is giving bad readings. Try running Apple Diagnostics by pressing and holding the D key immediately after you hit the power button to turn your machine on.
Score 2
2 Comments:
Thanks ,
I have run diagnostics , it shows ( Error:080000000000003, Cannot Load EFI/Drives/TestSupport
Status: 0x00000003
by
@flannelist - Looks like Apple has struck again killing diags on older systems!
by
Add a comment
Add your answer
Moe Shtewi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
