Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
MacBook Pro 2011 Won't boot from a internal SSD
Hi
My system will not boot if I put a Bootable SSD internal, the same SSD will boot from a USB enclosure, I have change the HHD Cable 2011 with one from Amazon and still no luck.
The system will boot fine from a 1.5t HHD internal or USB I can even boot from a SD card.
if I hold down the option key with the SSD internally the system sees it and the recovery drive but when I select it I just get the flashing folder..
so I have read that I should order the 2012 cable as it is much better then the 2011 cable.
any help wold be great
Terry
Add a comment
1 Answer
Most Helpful Answer
I would still replace the HD cable as SSDs run harder so a weak cable often shows up under it Vs a HDD.
Did you select it as your boot drive?
Score 1
2 Comments:
Yes I replaced the cable from Amazon and still no luck, but the same SSD will boot fine from a USB enclosure
by
@Terry Genereaux - Did you check the startup drive within prefs? Also did you install the same OS version your HDD has?
by
Add a comment
Add your answer
Terry Genereaux will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 70
