Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
No LCD backlight after replacing inductor
About a month ago I had to replace a missing inductor (L9004) on my early 2011 MacBook pro. I just got them in the mail today and successfully soldered the inductor. The screen now turns on, however now I have no backlight on the LCD. I know the screen itself isn't the issue and I'm unsure what to look for on the motherboard. For all I know I could've damaged something when I was using the heat gun. I'm still relatively new to all this stuff. If somebody could give me some tips on what to look for or test that would be great!
Add a comment
1 Answer
your problem is more than likely that your backlight cable was damaged during the process of replacing said part
2 Comments:
I had the display removed from the laptop when I was doing the repair so that eliminates the display cable. Do you have any other ideas?
by
try re connecting the cable. its possible debris got in between the backlight connection
by
Add a comment
Add your answer
Chase Simering will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 44
