Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Install windows 10 with boot camp failure
My macbook gets stop code: WHEA UNCORRECTABLE ERROR during windows install. Then restarts then get message your computer restarted unexpectedly windows install cannot continue please restart computer and try reinstalling windows.
This gets in a loop. Im using bootcamp and ive tried deleting windows partition within bootcamp and reinstalling several times fire vault is off and ive confrimed that via terminal. Any ideas on this?
Add a comment
1 Answer
At this point you need to run Internet recovery to wipe the drive and re-install macOS. Then you’ll need to upgrade it to the version you are currently running or newer if that’s possible.
Be aware you will loose everything! If you have an external drive which was setup as a bootable drive with your user account credentials you should be able to backup your stuff first.
Then try again, make sure you have the correct Windows version for the version of BootCamp you are using.
Add a comment
Add your answer
Aaron Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 216
