Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Battery not charging after changing battery and MagSafe
Changed battery a while back and it would not charge. Changed mag safe twice. Got wrong one the first time. LED never goes amber always green. MAC will work unless it’s running something demanding any kind of additional power. Laptop will then shut down. Not sure if I got a bad battery. Is it possible for my power adapter to power the computer, but somehow not charge the battery?
Is there anyway to test power adapter? Can I troubleshoot this to logic board? Should I get a new battery in case the one I received was bad out of box? Or do I just keep shotgunning the troubleshooting?
Add a comment
1 Answer
Chosen Solution
Contact the seller of the battery as the micro-controller within it is bad.
Score 1
2 Comments:
Thanks. I will try. I bought battery from iFixit in Aug of 2018 though. When it didn’t work, I didn’t think I got a bad battery and moved on to other things. I am finally getting back to trying to fix it and will most likely be on the hook for the battery.
by
@schmidtsd - Procrastination doesn’t help 😩
Even still see if they can help.
by
Add a comment
Add your answer
schmidtsd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 37
