0
Score
Chris
Asked
Random sudden shutdown issue
I've got a random shutdown issue affecting my MacBook pro.
I've had the graphics processor issue in the past and the apple shop replaced my logic board. I've also replaced the battery and maxed the memory to 3gb. Over the past year my MacBook pro has begun to randomly suddenly shut down. I've tried to diagnose it myself, memory passes all tests, logs do not show anything, the apple tests you can run at bootup all pass, temperatures look correct, fan speed looks and sounds correct.
My suspicion is a temperature sensor problem but I'm not sure.
Sometimes when turning on after shutdown the laptop will turn off again after about 10 seconds.
0
Score
Davis
Answered
*Disclaimer* This is a different model MBP than my own. It may be a COMPLETELY different issue. This is just my experience with what seems to be a similar problem.
Hey man. I had/have a similar problem with my a1260 mbp 15" (with so much surgery performed on it its basically like Joan Rivers. Major parts replace once, graphics card recall, entire top half replace...all different incidences). It became so bad (a little bit after the top half and a memory upgrade to 6gb) with the sudden shutoffs that I couldn't boot it up anymore. Battery in, battery out, charger in, positioned vertically, at an angle (read on for that fun bit), being very gentle with the CPU load...you get the idea.
However, before it became that bad, I noticed something odd. If I kept the laptop propped up by putting something that was about the thickness of two fingers put together at about the battery area, it would stay on (sometimes).
Now the bad news. The ability to change the behavior with changing the position made me think it was a short or a contact issue. I did some poking around and noticed that certain pressures on the power button of the top-case would cause the shutoff. Again, sometimes, and the pressure was not always necessary. It was some kind of short I believe. However, after running a stress macro, the problem showed its ugly head again. I tried going back to 2gb ram. I tried a number of things. Every time, the same issue.
I said "frack it" and brought it into someone a bit more knowledgeable than I, my local repair shop. They opened it up and almost immediately suggested that it was the left i/o board, citing that it may be an issue with the way power is distributed from the battery/charger
I'm now wondering if I can scrounge the board from another MBP somewhere in the world/my local sphere, live with the problem, or...perhaps buy a new laptop. Perhaps one that isn't so crazy expensive to repair or replace parts. I only hope that laptop supports Lion. :(
So here's the long and short of it Chris. The problem became so bad I would only hear the boot noise and then it would shutdown. A replacement top-case (ie the part with the speaker-holes) fixed the problem...sorta
Sorry buddy. But look at it this way. My laptop is from 2008, yours 2007 if I'm right. They're old man. It really sucks, but it may be time for us to replace our laptops.
0
Score
Charles Fisher
349
Answered
Hello there, it's been a while since I've access this site. Allow me to comment on this OLD matter that you had (assuming that you have resolved the matter by now), you know a lot these earlier Macbook pros appear to have this "common issue" that was never fully explained and although there are a lot of other factors that can contribute to the cause (compounding the initial problem) it would serve all users (who have these machines) to ensure that they have NO 3rd party software that the machine sites as a problem (by means thru the system profiler-Logs-Kernel log). Take the time and look thru the listing and see if you can identify any programs there that appears to be a problem, another way is to update all of your programs individually. Macs are very specific with their programs and there are some 3rd party software can give it problems you wouldn't expect and investigating this issue more deeply requires a lot of time and patience, it's not ALWAYS a defective logic board (now yes they can go bad i.e., certain components starts to "break-down" becoming erratic). Now here's food for REAL thought: if your machine has been opened up a few times you will want to look for any type of small problems that looks -huh: screws, single small wire strands, "dried" traces of spots between solder points of other components or exposed signal paths. Now, the thermal compound that is on the processors and video card can be a problem also. It has been said that the compound does not conduct electricity between solder points, I have found that when you find thermal compound that has spreaded to close to (touching) other solder points from the case of processors or video card I suggest that completely remove that compound from those components and the heat sink as well. Reapply fresh "Ceramique 2" thermal compound (it MUST be applied properly) to the components ONLY-not the heat sink, make sure you have examined it carefully for any type of distortion/stai
0
Score
Chris
Answered
0
Score
Charles Fisher
349
Answered
How long ago did Apple replace the board?
mayer,
Approximately 8 months ago.
Chris,
