A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 Questions View all
Replacing Fusion Drive in 2017 and 2019 iMacs (Leaving New NVME Only)
I don't have a problem with the physical replacement which I know is involved, but I wanted to make sure I understand the technology of the Fusion Drive.
1. I am under the impression that it is okay to take out both drives, and just replace the NVME with a 1TB (blade) NVME drive, leaving the 2.5" drive out of the equation completely. Is this correct?
2. Is there any reason to go through the process of splitting the drive in the software if I will not be using either of the two original drives again, or will that have ramifications within the system after I install the new drive? I guess I'm asking if it's OS level changes or system changes. I've not looked too far into that aspect.
Thanks!
Add a comment
1 Answer
Apple isn't so forthcoming, so what we did with the older systems and macOS's doesn't always translate to the newer systems and OS versions.
It's been awhile since I've done a de-fusion ;-} So I can't tell you if using Big Sur and newer alters things.
We do know Apple changed how Fusion drives were inter-linked with Catania requiring the blade cache drive be removed to install a replacement SATA drive (HDD or SSD). As it turns out the process of splitting the fusion drive set doesn't work.
So pulling both drives should allow you to install a replacement PCIe/NVMe drive.
Add a comment
Add your answer
Joseph Turner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 139
