Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
206 Questions View all
Battery flex cable damage?
In replacing my fan, I believe I may have damaged the battery flex cable. I pulled the flex cable out without lifting the seat, and then was able to place back without issue. However, now the computer will only turn on with power cable. If it boots up and I remove the power cable, it immediately dies. With the flex cable reseated, It does recognize the battery, says it’s at 100% and hardware test shows no issues. The computer will also boot up without the flex cable in at all, but will shower an X in the battery, so at least part of the flex cable must be working. I ordered a new flex cable, but what is the likelihood that the logic board itself is damaged from pulling the cable out this way?
1 Comment
Hey man this literally happened to me today when i replaced the screen how did the repair go after the new install?
by
Add a comment
Most Helpful Answer
Here's the replacement cable MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable
MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable Image
Product
$14.99
Score 1
Add a comment
this is the exact same thing that happened to my macbook. Any fix?
1 Comment:
Replacing the cable of its damaged or if the socket is damaged you can replace them as well but you need good soldering skills, and the needed tools and part.
by
Add a comment
Add your answer
Josh Alinger will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 20
All Time: 362
