Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Questions View all
Mac Mini A1347 Status Light Indicator
Hello All,
I have an interesting problem.
I bought a Mac Mini A1347 from Facebook Marketplace from an IT seller. He upgraded the RAM to 16GB along with a 1TB SSD, but in the midst of that, he said he must have bumped something because the front status light indicator does not function. The computer still works without issues, start up, and setup were like out of the box.
Is there a repair option for the status indicator light?
Thank you in advance,
TG
Add a comment
1 Answer
Most Helpful Answer
The White LED on the front panel is part of the power supply assembly Mac mini A1347 (Mid 2011-Late 2014) Power Supply It could be burnt out. Here's the guide to replace it Mac mini Late 2012 Power Supply Replacement
The other possibility is the power supply to logic board connection got damaged in the process.
Mac mini A1347 (Mid 2011-Late 2014) Power Supply Image
Product
$79.99
Score 1
3 Comments:
THANK YOU SO MUCH FOR YOUR ANSWER! It means a lot and make sense.
Would replacing the power supply fix if the indicator is burnt out or the connection got damaged?
by
Thats the hope! Unless the logic board connect its self is damaged so when you replace the PS check it.
by
Thank you so much for your input, Dan. I will be ordering the power supply and then replacing it. You rock!
by
Add a comment
Add your answer
Tin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 242
