Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Laptop won’t power on.
MagSafe charger still lights up green first and then turns orange when plugged in, but after 24 hours of constant charging, it still stays orange. I’ve done all the simple things (resetting SMC) and others, but I’ve come to my last resort. Do you have a solution?
2 Comments:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
Hi dan!
I can't install application on the mac because the thing wont even turn on..
Thanks!
by
Add a comment
1 Answer
Disconnect the battery following this guide to Step 6 MacBook Pro 13" Retina Display Late 2013 Battery Replacement. Then with nothing connected hold the power button for a good 15 secs. to fully discharge the logic board. Now carefully plug in your MagSafe charger the system should spontaneously startup, let it finish booting and then shut it down properly. Now disconnect the MagSafe connection and plug the battery again and then the MagSafe charger let it charge up and then see if it restarts, if not you need a new battery.
Add a comment
Add your answer
Lact Carol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 154
