Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Replaced battery 2 months ago, battery not recognised and system slow
Hi there,
I replaced the battery 2 months ago. the laptop was working fine. Out of the blue my laptop is not recognising the battery both in system report and cocunutbattery (see screenshot).
As soon as i disconnect the magsafe the laptop immediately shuts down.
Reset the SMC a couple of times, wiped PRAM, updated to the mac os - still no luck.
Score 1
Add a comment
Chosen Solution
Sadly the batteries onboard micro-controller has failed you’ll need to speak with the seller to get a replacement battery.
Add a comment
hey Arun Kumar, you should check the motherboard for something arround the battery area, it maybe the connector or something , well i have seen a problem like this before (not on mac btw) on a yt channel by some technican , he tried to fix some “throwed-away” laptop and one of them is same as your problem , this was cause by some small part inside the motherboard that was broken .
if this didnt help you out then u can search some yt video
Add a comment
Add your answer
Arun Kumar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 45
