The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
Shows adapter connected only when battery is disconnected!
Hello Guys,
I am facing a very peculiar problem. It all started when my laptop stopped charging or showing that charger is connected (not the problem “battery not charging”).. my laptop just don’t show any sign that the charger is connected nor the led light up on the charger.
I thought the charger had gone bad so bought a new one but same issue. Then I replaced the I/O charger board with a new one and the battery started charging.. I was happy and all but it charged only till 72% and stopped and again the old problem returned.. My laptop was giving me normal backup time from the 72% it charged to.
Then I started experimenting, what I found was if I disconnect the battery from the motherboard, the laptop detects the charger - the green led lights up - the laptop works normally. If I connect the battery while it is on - led turns to orange and the battery starts charging to 100% and led turns green.. and the laptop will work without any issue till I disconnect the charger.. once disconnected it will not detect again… till I disconnect the battery again.
If I charge the battery this way and disconnect the charger the battery gives me normal backup as it was supposed to.
What do you guys think is the problem here??
Those wondering why I am doing all this experiments.. the nearest apple service centre is very very far away.. so I have to fix it myself.
Images of CoconutBattery :
3 Comments:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
@danj snapshots added!! Thanks for the reply!!
The Power Adaptor stopped working after it charged to 100%.. now running on battery.. charger is connected but showing not connected..
by
Did you get a resolution to this? I have replaced both parts and still have the issue.
by
Add a comment
1 Answer
One of the problems I had seen in this older series is a domino effect! When a battery age forces the system to run the charging logic more often as the battery chemistry is not holding the charge, often causing both the MagSafe charger block to overheat as well as the charging logic on the main logic board.
So to fix this we need to replace two parts:
Here’s the needed guides to do the tasks:
MacBook Air 13" (Mid 2013-2017) I/O Board Image
Product
$79.99
MacBook Air 13" Mid 2013 Battery Image
Guide
MacBook Air 13" Mid 2013 Battery Replacement
Difficulty:
Moderate
15 minutes
MacBook Air 13" Mid 2013 I/O Board Image
Guide
MacBook Air 13" Mid 2013 I/O Board Replacement
Difficulty:
Moderate
25 - 45 minutes
2 Comments:
Thank you too much for the reply!!.. I already replaced the I/O Board.. which was of no benefit.. and talking about the battery part - is there any way to know for sure that the battery replacement will solve the issue.. I mean if I buy the battery and the problem persist... it will be another waste of money.. Batteries are not returnable on amazon and ifixit won't ship to my country..
thanks..
by
@ashlife - I can't answer your question in that context. Lets use a car as an example... Your cars battery is old so it often works but when the weather is cold or very hot the battery won't start the car.
Here we have the same issue as like a car battery the chemist of the battery over time breaks down! This is the original battery which is now over 8 1/2 years old. Would you run a car with such an old battery?
So the answer is you need to replace it, is it the only thing that needs fixing, it many not be. But you can't answer that until you know the basics are dealt with first.
by
Add a comment
Add your answer
Ashlife will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 165
