Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211 Questions View all
MBP 16" 2019 - SSD chips changed, how to bypass T2 chip?
Hi,
My MacBook Pro 16” from 2019 died because of a SSD short circuit. I had and independent reparator look at it and they swapped out the dead SSD chips with new ones (they unsoldered the older one and soldered new ones).
Now the Mac does accept power (touch pad clicking) whereas it did not before the ssd chips were replaced, but they told me due to Apple’s T2 chip it wouldn’t boot.
Is there any way to bypass this chip or reset it?
Currently the Mac screen is black, tried using Apple Configurator but got error: The operation couldn’t be completed. (AMRestoreErrorDomain error 6 - Failed to handle message type StatusMsg (Operation failed)) [AMRestoreErrorDomain – 0x6 (6)]
Regards,
Score 1
Add a comment
Chosen Solution
Sadly, the T2 chip is the controller logic to the Flash chips.
It was suspected the T2 logic accesses a burn’t in code of the Flash chips and once done you can’t alter the logic. Replacing the T2 chip is really not possible either.
Sadly you need a new logic board.
Score 2
Add a comment
The SSD module in the 2019 Mac Pro is replaceable. However, there is a specific procedure you must follow after replacement. That procedure is outlined in this Apple support Document:
https://support.apple.com/en-us/HT210626
This may or may not work with a different model (such as the MBP), however it seems reasonable to assume it will.
Score 1
Add a comment
Add your answer
Lucas Decrock will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 58
All Time: 1,303
