The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
172 Questions View all
What is this white stuff on the power supply?
I opened it up to check on the clock capacitor and got scared that the capacitors on the power supply had leaked out and was somehow still working.
Xbox Power Board Replacement
Every replacement power supply I found and the one in this guide also had it though. Is it just bonding?
Score 2
Add a comment
1 Answer
Most Helpful Answer
@alexanderson that is some silicone based “goop” that keeps the components in places, isolated from the other components and stops them from vibrating. PITA to remove it. Most of the time I use a heatgun and a dental pick. No fun and messy but normal stuff.
Score 6
7 Comments:
Okay that's good to hear. What would you recommend to get the main board nice and clean? Currently there's a thick amount of dust in there.
by
Start with a brush and brush the lose stuff off. Then use a bit of compressed air or a shopvac (or similar) and blow the more resistant stuff off. Keep on brushing the dust off as it gets lose from the air.
by
You can usually remove them without removing the stuff, but you need to remove all of the solder. I've done it out of laziness before. It's more prone to risking PCB damage yes, but if you do it right it's a huge time saver - just don't re-apply new goop.
by
@nick - I always put back the thick silicon damping potting after replacing the ones that are potted. Otherwise your power supply will ring! The caps and coils oscillate to the 60Hz cycles or its harmonics.
by
@danj Heh I never notice, tbh.
by
Show 2 more comments
Add a comment
Add your answer
Thomas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 58
All Time: 1,658
