Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Power supply works when logic board is disconnected.
iMac is dead.
I tested the power supply separately from the logic board and all the pins match the expected amounts. When I attach it to the logic board, all the pins are dead, zero volts everywhere.
Q: Does this mean there’s a short on the logic board? Wouldn’t the pins still show a voltage since the short is drawing power?
Q: Do I need to supply voltage to the board to find the short?
Add a comment
1 Answer
Yes, you have a short within the logic board, often it’s the MXM GPU board that fails.
Time to pullout the DVM and check the power rails for a short (without the power supply connected). You’ll need the board-views and schematics for the system.
3 Comments:
DVM? Digital voltmeter, right? (Just checking) ;)
by
Also, can I assume that the power supply is prob OK?
by
@Paul Spinelli - Likely, you really need to test the logic board power rails for a short
by
Add a comment
Add your answer
Paul Spinelli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 53
