Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
342 Questions View all
iMac is woking but screen is screwed
Hi all,
is there any way to fix this?
Update (12/17/2021)
OK I managed to make the external display work: the imac was running Linux, and the second screen attached to the mini displayport through an HDMI adapter get no signal. So I created a Mac OS X installation boot usb stick and booted by USB. When running the OS X installation program, the second screen attached to the mini displayport was running fine.
Therefore I think the problem is in the screen.
Score 1
3 Comments:
Does anything happen if you connect an external display?
by
External monitor attached to the minidisplay port with a mini displayport to hdmi adapter says no signal.
by
@golivag - Your new test proved the internal display is bad, time for a new one.
Please score and accept my answer - Thanks!
by
Add a comment
1 Answer
If the external monitor shows a clean image then you will need a new display. Follow this guide iMac Intel 27" EMC 2639 Display Replacement and here’s the needed part 2012/13 27” iMac Display Assembly, Apple P/N 661-7169
3 Comments:
by
@golivag - Not good ;-{ Your logic board has issues!
It might be repairable but its going to take someone with deeper skills and access to the needed tools to fix this. Or, you could just replace the logic board TheBookYard UK - Possible logic boards that will work in your system for one source that should have what you need.
by
Well, your new test point to the display which is what I had thought!
by
Add a comment
Add your answer
Gennaro will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 48
