Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
My smc reset isn't working and the battery isn't charging
My SMC reset isn't working and the battery is also not charging, I tried changing the battery to see if it was faulty but the other one still wasn't charging and I also changed the MagSafe but still it wasn't charging
The battery is now dead and it won't start up, the MagSafe light is green, and the battery meter by the side (the one that has a tiny button) blinks 3 times then the last one fades out
It also starts itself automatically when i plug the MagSafe and doesn't boot up but it keeps beeping continuously (this started happening after I unplugged the battery indicator from the inside, i returned it but still)
Please help!!
Add a comment
1 Answer
The blinking battery checker is telling us the battery is no longer good. The cycle count has exceeded the 1000 cycles!
Reference: Determine battery cycle count for Mac notebooks
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here’s the guide MacBook Pro 13" Unibody Late 2011 Battery Replacement
If the MagSafe charger’s LED is not lit then your charger and/or the MacBook Pro Unibody 13" and 15" MagSafe DC-In Board needs replacing MacBook Pro 13" Unibody Late 2011 MagSafe DC-In Board Replacement
The MagSafe charger needs to light up and will be either Amber - Under charge or Green - Charged.
I often find people use cheaper knockoff chargers which damage their system does your MagSafe port look like this?
You may have other hidden damage inside as well.
Or… your MagSafe cord have damage like this
Make sure you get a REAL Apple unit and the only way to be sure is to get it directly from an Apple Store Apple 60W MagSafe Power Adapter (for MacBook and 13-inch MacBook Pro)
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Image
Product
$9.99
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery Image
Product
$69.99
MacBook Pro 13" Unibody Late 2011 Battery Image
Guide
Difficulty:
Easy
5 - 15 minutes
MacBook Pro 13" Unibody Late 2011 MagSafe DC-In Board Image
Guide
Difficulty:
Difficult
45 minutes - 1 hour
2 Comments:
The magsafe is lit(shows constant green) I've changed the charger and the battery but all to no avail so I dont its from either of these but the system doesn't charge or boot up, it just keeps beeping and I've adjusted the ram also but to no avail, smc reset isn't working maybe because it's not charging in the first place
by
@Abdallah Moha - OK, Green is good! Did it start off Amber and then turned Green.
Not sure why you are messing with the RAM as that won't alter things.
To force a SMC reset just disconnect the battery and then press the power button for a good 15secs so you fully discharge the logic, then plug the battery back in, the system should spontaneously restart on its own if it doesn't then you have a deeper problem.
If you do get the system to boot up, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
Add a comment
Add your answer
Abdallah Moha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 895
