Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 Questions View all
Diagnostic LED 1 blinks once
so i’ve recently been given a Mid 2010 27” iMac that wasn’t powering on. Initially i thought i must most probably be the Power supply that had croaked it and needed to be replaced because when i plug in the power the diagnostic LED 1 flashes once then once again but not as bright that second time, as if it was loosing power. No other LEDs are lit.
I have replaced the PSU with a known working unit but still getting the same thing.
im hoping its not the logic board that has an issue or a short on it,
is there any chance it would be the jack/EMI unit where the power goes into the imac?
Add a comment
1 Answer
You have a short within the logic board and/or the MXM video board.
My money is on the video board! Do you have the correct one to test things?
Otherwise its following the power rails with a DVM and a set of schematics and boardview drawings.
2 Comments:
Thanks! But darn was really hoping for the video board being the issue. Removed it but am still getting the same problem.
Must be a short on the logic board then.
by
@ahkoo - Follow the yellow brick road ;-}
Get a DVM and a set of schematics and boardview drawings following the power rails and check the caps.
You might want to find someone with the deeper skills to help you.
by
Add a comment
Add your answer
Ahkoo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 31
All Time: 218
