The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
MacBook Wont turn on over battery (just ac could turn it on )
My macbook can be turn on only with ac power adaptor. (battery detected but not functional)
If i unplug the ac its turn off imidietly and buttery do nothing. ( Battery detected and charging well in os )
I tired all the smc and nvram and … reset.
Note. : It was fine before i just opened and clean it then this problem appear.
  • Magsafe light start with green then stay orange even without battery
  • Auto boot after plug the ac.
Update : this ic looks diffrent ( white buble inside ) ( check the target line in uploaded pic)
This buble mean the ic goes dead ?
Whats the name of this ic? Or could have relation with power source ?
4 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
When you opened it to clean, how/what were you cleaning. Did you take components out?
If the issue wasn't occurring before cleaning it out, sounds like something happened in the process.
by
@flannelist i think i found the problem. Check the update
by
@danj its not from battery. Check the updated post. I think i found the problem
by
Add a comment
1 Answer
Most Helpful Answer
OK you found the comparator resistors! And the one you pointed to R7006 has failed! This happens when you use a knockoff charger as they over power the circuit.
Time to find a local independent shop which can micro-solder and have access to the needed part.
Score 2
1 Comment:
Oh tnx for the schematic. I really looking to knowing that. I will go to local shop they can replace 7006 and update the post.
by
Add a comment
Add your answer
Mostaf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 64
