Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
406 Questions View all
Black Screen on boot - May not be detecting external
Hello-
My macbook pro 15” from late 2011 is having the typical issue of black screen on boot: took it to apple and was told the display was busted so I’m now testing it with an external. The external monitor does not seem to be detected in this process (or maybe this is just the graphics card not working?) as the power light on the monitor stays orange and nothing ever seems to trigger anything on the screen.
Does anyone have any ideas? Or is the graphic card just blown?
Edit: There is no light on the charging port when it’s plugged in, and when I press the power button the fans come on very high speeds.
Thank you!!
Add a comment
1 Answer
Chosen Solution
Carefully disconnect your systems battery following this guide MacBook Pro 15" Unibody Late 2011 Battery Replacement Stoping at Step 4. Now press and hold the power button for 15 secs so you fully discharge the logic board. Now carefully plug in your MagSafe charger, press the power button, and then press and hold the T key. At which point you should see the FireWire or Thunderbolt Icon on your internal displays screen. Do you?
If not plug in your external display. Did you see it then?
Update (10/13/2021)
@tjones123 - Sadly your logic board has had it. This test was to see if we even can get the CPU's graphics engine to work. Someone with deeper skills might be able to replace the damaged components. In the end you won’t get a better GPU which is the weak point in this series.
At this point I think your best bet is to replace the logic board. Now you could go for another 2011 board or what I strongly recommend is jumping to a 2012 board. This is one of the rare cases this is possible! Apple put a better CPU and GPU chip on the 2012 board. In fact I’m banging way on such a converted system right now.
Here’s the needed part:
  • 2012 15” Logic Board - 2.3GHz i7 - Apple P/N 661-6491
  • 2012 15" Logic Board - 2.6GHz i7 - Apple P/N 661-6492
  • 2012 15" Logic Board - 2.7GHz i7 - Apple P/N 661-6493
And here’s the guide to put it in MacBook Pro 15" Unibody Late 2011 Logic Board Replacement. This is one slight modification needed to the LVDS cable
The tricky part is finding the part! Even the 2011 boards are getting hard to come by as well.
MacBook Pro 15" Unibody Late 2011 Battery Image
Guide
Difficulty:
Moderate
10 - 45 minutes
MacBook Pro 15" Unibody Late 2011 Logic Board Image
Guide
Difficulty:
Moderate
50 minutes
Score 1
1 Comment:
Ok I completed the steps:
The magsafe charger now has a green light when plugged in with battery cable detached. Nothing on either internal or external display
by
Add a comment
Add your answer
Todd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 70
