Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Questions View all
What is the correct BLADE SSD I should use?
Try to upgrade my 2012 iMac 27” with a blade SSD, but not sure if the following one I saw from eBay the correct part, can any one give an advise? Thanks.
SSD 128GB MacBook Pro Retina 13" & 15" 2012 2013 A1398 A1425 | 661-7008 661-7285
1 Comment
Add a comment
1 Answer
Most Helpful Answer
Your iMac’s Blade SSD connector uses custom to Apple mSATA III (6.0 Gb/s) SSD. Apple offered five different sizes: 64, 128, 256, 512 & 768GB
Your other choice is using an OWC mSATA III (6.0Gb/s) SSD drive OWC offers four sizes 256, 500GB as well as 1.0 & 2.0TB
I strongly recommend you go with either of these choices. Sadly, your system does not support the faster PCIe/NVMe SSD’s and M.2 SSD’s won’t work as the physical interface is not the same.
Score 1
2 Comments:
Thanks Dan! By the way, by looking at the link you gave, I did see part number 661-7008 mentioned there, thus, the one I saw from eBay should work for my iMac, right?
by
@lovecd - It should
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 50
