Unable to boot in recovery mode or reset NVRAM or Pram
I have a 2013 Macbook air that I did an erase and reinstall. Everything booted up fine. The next morning I got the question mark Icon at start-up.
I then powered down and re-booted in Recovery mode. Nothing. Black screen. Went through the NVRAM/PRAM process (command, option P+R) at startup.
Screen blinks as it chimes, blinks again at second chime. Still have black screen.
Dead drive?
Well it does sound like you have a SSD issue. So can you give us a bit more on the drive make and model. Post a picture if that helps Adding images to an existing question
by Dan
Honestly I do not know. It is a a 2013 Macbook air. 8G hard drive... How would i go about finding out type and then replacing?
by Matthew Agostinelli
Pop the bottom cover off following this guide MacBook Air 11" Mid 2013 SSD Replacement Stop at Step 2 and then take a picture of the SSD it should have a label on it, if not finish following the guide to fully remove the SSD and look on the other side and take a picture of the label on that side Adding images to an existing question
by Dan
@ibreakit55 - Can you post the other side which should have a label. Need to see it.
by Dan
I posted the other side...
