Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Can’t reinstall macOS to upgraded SSD
So I was gifted an old Mid 2010 MacBook Pro that at this point, I’m ready to just give up on. I purchased a Samsung 970 Evo 2.5 in. SATA SSD (250GB) and could not reinstall macOS no matter what I tried. I tried Internet Recovery, I tried using a USB installer and I continuously get the “prohibitory symbol” when it’s near completion of being installed. I’ve tried on both WiFi and Ethernet, same results. However, I can reinstall macOS if I throw in the original HDD but for obvious reasons. So I figured, let me see if the SSD is the issue and so I purchased a SATA to USB Cable and was able to successfully reinstall macOS onto that externally. Then I came across a thread on here that suggested upgrading the internal Hard Drive Cable, which I purchased and arrived today. I successfully installed it and once again tried to reinstall macOS to only get the same issue again! I can install macOS to the SSD if connected externally and can install it internally and it boot up fine but if I restart the computer it will boot to the “prohibitory symbol” It’s like it doesn’t like the SSD installed internally but will accept it externally? I don’t know what to do at this point. Anyone have suggestions or ideas? I’m beyond frustrated and usually can figure out these sort of things on my own but figured I would reach out for help on here. Thanks in advance to anyone who responds to this lengthy post.
Add a comment
1 Answer
Using the USB boot drive did you first format the drive fully to GUID Journaled file system? Are you using the correct OS version? The highest you can go to is macOS High Sierra (10.13.6)
2 Comments:
@danj I did make sure it was formatted correctly and I figured I would reinstall macOS externally since I know that works and then just install the SSD and it should be okay. However, when I restarted the computer it gave me the prohibitory symbol once again. I found an Apple Support Communuties thread that indicated the issue is on the server side and that they only fix was to take it to the Genius Bar. I don’t understand why this couldn’t be reinstalled using a USB bootable installer which I have but also starting to wonder if the hard drive cable was even necessary since I’m still having the same issue.
by
@fidelg - Ah! You did it externally, then you need to restart your system using the Option (⌥) to gain access to the Startup manager to select your new drive. Then once you've booted up go into your systems preferences and alter the Startup Disk to alter it to your new drive.
That way the drive is blessed as the startup drive.
Reference: Mac startup key combinations
by
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 57
