Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
New keyboard installed, but some keys are too sensitive
I bought the ifixit repair for the keyboard and installed it. Before it didn’t turn on due to coffee spill, now with the new part it does turn on, but some keys (3-4 keys is all) are SUPER sensitive. Like you can just run your fingers over the keys and not press and they’ll type. My son is using a USB keyboard for now, but I think I’ll have to tear it back apart to see if I can find a reason why the keyboard isn’t working properly. Has anyone seen anything similar?
Score 1
1 Comment
I have this problem too! All you have to do is brush the keyboard and it all guys haywire. Sounds like a defect I'm about to ask for an exchange…
by
Add a comment
1 Answer
Most Helpful Answer
You’ll need to go back in and loosen the keyboard screws, then tighten them up just snug working from the center group outwards. I’m suspecting you have either distorted the case by pressure or the screws are building tension on the case.
Score 1
2 Comments:
also ( im not sure) but if there are different length screws in the disassembly to put them back in the right spot
by
@logixal - The field of 45+ screws are all the same make sure you haven't bent the aluminum uppercase frame, as I've seen a few which needed straightening.
by
Add a comment
Add your answer
Neil Young will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 15
All Time: 370
