Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Questions View all
Fan running hard all of the time
Hi All!
Really need some expertise here. I have the same issue as most people here, but on an iMac 24” mid 2007 (A1225). Does anyone know what resistor i should be looking for? I replaced the CPU fan, just to find out it had nothing to do with it. Finally got to this page, but, according to the pics posted, the solutions are for a 2009 iMac…. right?
Thx
Update (01/28/2021)
Also,  i had istalled a while ago the SSD fan control and it worked fine.... since the fan gos into full speed the app shows as in the photo....
Well, it shows no info… no temps, no speeds…. nothing totally blanc….
Update (01/28/2021)
Here’s the TG Pro outputs:
https://drive.google.com/file/d/1AuoXG6n...
https://drive.google.com/file/d/1gsM5b7g...
9 Comments
Does your fan go into full speed right at the second of power on, or does it take eg. 1/2 a boot?
Why did you disassemble it?
Did you swap HDD to SSD or anything else?
by
It goes into full speed from the get go, constantly.. Just changed the fan, due to the full blast and noise…
by
Oh, and i swaped the left speaker too….
by
Tell me what screenshots you want please if these arent useful.
by
@nunon311 - Are you able to read them and have the needed tools? If not best to just replace the logic board.
Do a google search for them.
by
Show 4 more comments
Add a comment
1 Answer
Chosen Solution
Did you transfer the thermal sensor from your old HDD to your SSD? Review Step 20 in this guide iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
You should also run diagnostics from the original grey disks you got with the system. Did any errors pop?
Update (01/31/2021)
Well we know the issue is not the fan’s as SMC is working!
But we still are encountering a SMC error condition which is the voltage sensor firing off on your logic board likely within the CPU VRM logic area.
This really needs serious circuit level diagnostics. Do you have the schematics and boardview drawings for this system? Do you have a good DVM and the skills to read and test at the component level?
Your other option is just finding another logic board to replace this one that might be the cheaper solution.
Score 1
5 Comments:
HI. I didnt replaced the HDD for a SSD. The thermal sensor is in the place it should be...
by
I cant run diagnostics coz i dont have the disks any longer..
by
@nunon311 - OK, You'll need to give another App a try to see
what it can tells us.
You'll need to get the older full version of this App TG Pro you'll need the full version contact support@tunabelly.com asking them for the older version for your OS-X version - El Capitan 10.11.6 ??
by
Hi Dan!
Yes, im running El Capitan..
I have TG Pro installed. I took a couple of screenshots to show you, but somehow, i cant upload them…
by
I dont have the schematics and boardview drawings
by
Add a comment
Add your answer
Nuno Nogueira will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 128
