Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
Chime, black screen, no PRAM reset, help!
Hi folks,
I've had my 2308 iMac since new. It was working just fine, and then one day I came to switch it on and got the chime, but nothing else. Blank screen, no response, etc.
I have attempted to reset the PRAM/SMC with wireless and wired keyboards, and tried to boot in Recovery mode: nothing.
I also hooked up an external display: again, nothing.
Having looked though the vents on the bottom, I can see two diagnostic LEDs lit (as this model has integrated graphics, I'm assuming there should be three lit?)
Any ideas?
If it helps, service history: about 4 years ago, I replaced the original Seagate drive (broken). Everything seemed to work fine after that, although the optical drive stopped reading discs.
1 Comment:
Lets give this a try! Take a flashlight placed on the screen at a sharp angle you should see the faint image of your desktop and its icons. Do you?
by
Add a comment
1 Answer
If you do see the faint image of your desktop and icons that tells us the displays backlight has failed. Most likely the LED Driver Board needs replacing ''iMac Intel 21.5" EMC 2308 LED Driver Board Replacement
3 Comments:
Hey Dan - tried that with the front glass off and couldn't see anything :(
by
@sandytoucan - Not good ;-{
This then sounds like a dead GPU which means the logic board will need replacing iMac Intel 21.5" EMC 2308 Logic Board Replacement
by
That's what I thought might be the answer :(
Thanks for your input – it's not my main computer any more, so might try to convert it into an IPS display rather go through the logic board ordeal!
by
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 68
