Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
Why is my new iMac video card not working
Hi all,
I have an early 2008 24” iMac, top of the line with a 3.06GHz Core 2 DuoCPU and NVIDIA GeForce 8800 GS GPU.
The issue is that when I turn it on I get nothing on the display at all. It also takes the Mac a few attempts to power on (what I mean by this is that when you press the power button you can hear The Superdrive starting up, the fans start for a second and then the Mac powers off for a second, and then powers itself back on. It does this twice or thrice until it successfully powers on with nothing on the LCD and the fans at 100%)
The problem I’m having is that after buying a Radeon 2600 Pro to replace my old dead GPU board, nothing happens. No fans nor is the SuperDrive spinning. I went to check the diagnostic LED’s: 1 is always on, 2 and 3 are blinking every few seconds and LED 4 is off.
When I remove the GPU board altogether or add my old 8800 GS back in to the system, the fans go completely full blast. At this point All Diagnostic LEDs are lit except for LED 4. Does anyone know what’s going on here?
Thanks In Advance, Kyle
Edit: just noticed that the when the LED flashes momentarily you can also see the fans move a very slight bit, so i believe it’s trying to power on but there’s something stopping it
2 Comments:
do you have chime tone?
by
@David444 thanks for the reply,
But I can’t hear the boot chime unfortunately
by
Add a comment
1 Answer
Sadly, the replacement GPU board won’t work in your system. The best you can use is a ATI (AMD) Radeon HD 4850. The version of MXM your system has won’t support the Radeon HD 2600 Pro
The GPU Specs your system can support:
NVIDIA GeForce 9400M PCI-E 2.0 x 16
ATI Radeon HD 4850 PCI-E 2.0 x 16
The GPU you are trying to use:
Radeon HD 2600 Pro PCI-E 1.0 x 16
6 Comments:
Thanks so much for responding, but i think you may have mistaken this Mac with the 2009 iMac, as this is an Early 2008 iMac the GPU should be compatible (hypothetically of course)
by
@Kyle Byrne - Apple upgraded the system, I was never able to get the older MXM board to work.
by
@danj Oh dear, so would i even be able to buy an 8800gs to use in this system or only the GPUs you listed in your first comment
by
See if this works NVIDIA GeForce GT130
by
@danj well I’ve put myself in a pickle now, because i have an Nvidia 8800GS on it’s way because i was worried that something would go wrong with the AMD 2600, so I’m assuming that I’ll have to sell these again as untested if I’m unable to return them
Fairly annoying because i bought this machine with bad Graphics for like €40 as a project machine. But then i had to buy a new Power Supply because the old one went bad. And now I’m after messing up with the GPUs, putting more money down the tank
by
Show 1 more comment
Add a comment
Add your answer
Kyle Byrne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 187
