The Moment is a midrange USA-exclusive slate QWERTY slider Android smartphone released by Samsung in November 2009 for use on the Sprint (now T-Mobile) network. Identifiable by model number M900.
1 Questions View all
remove apps not using
Can you remove apps? That you do not want too make your battery last longer?
Add a comment
Most Helpful Answer
To uninstall apps that you installed, go to the menu, then to settings, then applications, then manage applications, then tap the app you want to remove, next a screen will pop up with the option to uninstall.
Some apps, however, are rooted to the phone and require more work to uninstall. For more information on this topic, I found this forum helpful: http://androidforums.com/samsung-moment/...
Hope this helps!
Score 1
Add a comment
To begin the process of removing an app, go to the home screen and tap "Market" (note: if your market shortcut has been removed, open the 'applications' tab and select market). Next, tap "my downloads." Once under your downloads, select the app you would like to delete, and click "uninstall." A confirmation screen will then come up; tap "ok." You will then be asked why you wish to uninstall the app. Once you select your reason, the app will be deleted.
NOTE: the app may still appear for a short time under "my downloads." This is so you can rate, comment on, or redownload the app. This does not mean the uninstallment was unsuccessful.
Score 1
Add a comment
If I go to root, can I get a list of the apps that can safely be removed as there are many that have unhelpfulnames
1 Comment:
I want to remove apps I have not downloaded. I imagine they came with the processor. Do I have to go into root?
by
Add a comment
Add your answer
gofordad57 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 284
