Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 Questions View all
resistors missing help! 2010 i7
So this is the story:
I have some keyboard key’s that aren’t working. I changed the keyboard but still the same buttons are nlt working. I can see on the motherboard that i miss some components.
whats the solution?
Update (09/20/2020)
Yes it’s ‘820 2850 A’ :D @oldturkey03
Update (09/20/2020)
Good question! I took a picture. The red ones
Add a comment
@melkhalfi
To clarify, these components are not populated in production systems as you can see here:
So this is not your issue. Can you fill us in on what’s going on which keys are not working?
Update (09/20/2020)
The keys you marked share three column lines:
  • The first being the 9, O, L as well as the colon key
  • The second being the 0, P, M and equals key
  • And the third is the accent, return & arrow keys.
This is common problem when there was a liquid spill which has damaged the keyboard switch lines under the keyboard keys.
Basically, you have a grid of X lines and Y lines and the key shorts across these two lines to create a circuit the computer understands as a given key symbol.
Sadly, there is little you can do to fix this other than replace the keyboard unit MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard its a bit of a job as you need to strip down the uppercase to get to it, here’s a great Youtube guide: 2009 Macbook Pro 15" A1286 Keyboard Replacement which is the same process for your system.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard Image
Product
$19.99
4 Comments:
Oh oke, so I have some keys that are not working. I replaced the keyboard but still they are not working. It does the job with an external keyboard. :(
by
What are the letters/numbers or function that don't work please.
by
I have updated my question. Thanks for helping :)
by
Thank you for the answers.
by
Add a comment
If you’ve changed the keyboard and the fault is still there then the issue is clearly the logic board and that should have been obvious.
You’re issue is likely the keyboard connector pins are bent and needs a new connector soldering(very delicate work) or liquid damage corrosion to a joint or probe point which can be fixed with enamelled jumper wire.
Add a comment
Add your answer
Melkha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 133
