2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
266 Questions View all
Display intermittently has rolling lines
Hi all,
My Macbook Pro 13” Retina late 2012 (A1425) has fast pulsating rolling lines in the display. Very intermittent problem, might only happen for 5 minutes in a 8 hour work day.
Sometimes twisting or putting pressure on the display or lower body will fix it.
Problem does not occur with external display & screen capture doesn’t record the lines.
Do you think it’s most likely the display cable or connectors?
Add a comment
1 Answer
Most Helpful Answer
It’s clearly something within the display its self. I’d say its quite odd! The only thing I can think of is the T-CON logic within the display (at the bottom edge) is messing up. Unlike older Unibody systems which used LVDS signaling your retina model uses eDP signaling. Its like the difference between Analog Vs Digital TV signals, that removes the cable as the source of the problem.
Here’s a breakdown of the display assembly MacBook Pro Retina Display Teardown
At this point I fear you need a new display assembly.
Reference:
Score 1
2 Comments:
Oh bummer, thanks for the info.
Any reason you don’t think it’s the cable given the problem is intermittent and sometimes fixes itself when I move or twist the body and/or hinge?
by
@jamesbartle - The signaling system is radically different so if the cable was the issue it wouldn't offer an image.
Think of it this way your radio is set for a AM station but the band selector is bad and jumps to FM band but the location on the FM side has not station so your radio goes from a working AM station to dead air on the FM side. This is like how Digital TV works it works, it just works or doesn't (eDP). Now let's say your AM radios tuner drifts the signal gets garbled (LVDS).
This issues is strictly something in the scanning of the image to the LCD which is done within the T-CON board. Somehow the circuit breaks down just enough to lose its timing. As its only on your internal display its got to be within the display assembly Vs the GPU logic.
I'll admit I have not encounter this before, but there's enough clues here to tell us what part is failing. The other direction would be a problem within the MUX logic on the logic board. I have never seen any scanning defect originating from it, I have only seen T-CON issues.
by
Add a comment
Add your answer
James Bartle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 140
