2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
266 Questions View all
Wifi and bluetooth not detected + ports on right side not working
Model A1425
Macbook was dropped from <1m height and now says
  • “Wi-Fi: No hardware installed" and
  • “Bluetooth: Not available".
I have recently realised that the ports on the right side are not working either. This wasn't a problem before dropping it.
  • Usb port is completely unresponsive.
  • With the hdmi, the screen goes black for a second as if it recognises that the cable has been plugged in (this is usual) but then nothing happens.
I have done a couple of things to try solve the problem.
  1. Initially, I thought it was the wifi card. I took it to Apple and they “confirmed" that it was the wifi card that was faulty too so I replaced it. The problem wasn't solved.
  2. I also saw on two posts here saying it might be the I/O cable that is loose or broken. I tried taking off and re-attaching mine but it didn't help so I bought a new cable… but still the same problem.
Do I have to replace the I/O board or logic board now…?? I don't know what else I could do. I'm thinking I might have to replace the I/O board since the ports on that side have stopped working as well as the wifi card so surely if not the cable then it's the board that's the problem?
Add a comment
Chosen Solution
Replaced I/O board and now it’s working.
Add a comment
Sounds like the I/O board cable has become dislodged or is damaged. Follow this guide to get to it MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable Replacement
3 Comments:
Thank you. However, I mentioned in the post that I've already done this. I've decided to replace the i/o board on the right side so hopefully this will fix it.
by
@el123 - Sorry, I jumped ;-{ Then its the board then.
by
@danj Yep it worked! :)
by
Add a comment
Add your answer
Eli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 339
