Self-priming automatic electric pumps with helical gears, produced by Marco.
28 Questions View all
Can I reverse the direction of flow on my oil pump - RESOLVED
Can I change the direction of flow by simply reversing the positive and negative connection to the UP2 oil pump ? The direction is backwards for my application in where it needs to be mounted.
2 Comments
Do you know the construction of the pumps impeller?
Many are directional so while you might be able to run it backwards you lose the effectiveness of the pump!
Maybe you need to look as the piping to it, can you reverse the connections?
by
They look like bronze helical gears and piping the system another way is unfortunately not possible. It would be sloppy and cumbersome looking.
by
Add a comment
1 Answer
Most Helpful Answer
It’s been confirmed by the manufacturer. It’s okay to reverse the wires going to the pump to Reverse the direction of flow. The discharge side will become the inlet side.
Score 1
Add a comment
Add your answer
Paul Cioletti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 303
