2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
Bluetooth not available, even after replacing Airport card
I had this issue where my bluetooth would sometimes just disconnect, so I figured the solution might be to replace the airport card. I did this and it worked fine for a little bit, but now the problem is back. There’s some software fixes I tried, like deleting the Bluetooth.plist files and resetting the NVRAM, basically anything I could find on Apple’s forums and on here. Is there anything else I should look into fixing?
Add a comment
1 Answer
Most Helpful Answer
Messing with the software won’t fix this! Hopefully you can undo the alterations.
To fix this properly you’ll need to replace the MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable you may still need a new I/O board if it is corroded from a liquid spill.
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable Image
Product
Score 1
2 Comments:
Alright, thanks for the suggestion. I'll try it out and accept the answer if it solved the issue! And don't worry, I didn't make any drastic changes software-wise, just reset a few things that can easily be reverted.
by
Quick question, I found this guide MacBook Pro 13" Retina Display Late 2012 I/O Board Replacement. From the pictures, it seems like the data cable is accessible without removing the heatsink assembly. Is this correct? That would make the operation a bit easier. EDIT: Never mind, found the repair guide for the data cable only MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable Replacement
by
Add a comment
Add your answer
Yorrick Bakker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
