Model A1199 / 2, 4, or 8 GB capacity
85 Questions View all
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
Score 1
Add a comment
Most Helpful Answer
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
Score 2
Add a comment
screen unlock system rebooting and taking off the code.
1 Comment:
Would you mind putting this into a complete sentence?
by
Add a comment
Repair on my screenlock chromatic code 2generation code.
1 Comment:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
by
Add a comment
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
Add a comment
Add your answer
fran will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 12
All Time: 6,079
