The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 Questions View all
Starter wont disengage, why
I have replaced the starter on my 2000 chevy cavalier with 2.2L engine 2 times in 3 days, it works great at first but will not disengage, there is nothing wrong with the flywheel, not sure how to fix it or what to check.
1 Comment
I figured out the problem, the person that put the first replacement on had a wire in the wrong spot. Thanks for the help
by
Add a comment
1 Answer
Chosen Solution
Check the spacer in the nose end of the stater. If it is missing the bendix gear will extend to far into the flywheel causing it to hang in the engaged position.
Score 1
1 Comment:
When I put the starter on it did have the little sleeve but when I took it back off not even a day later it was chewed up
by
Add a comment
Add your answer
Jwanna C will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 15
All Time: 109
