13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
How to retighten hinge after loosening/replacing
i have a 2.0GHz unibody macbook A1278.
i have previously upgraded my ram to 4Gb ( the price difference to 6Gb at the time was too exorbitant to afford)
and replaced the 120Gb HDD with 500Gb.
my latest venture has been to place the LED lighting mat under my keyboard and now i have backlit keys and a clean processor fan and radiator as a result. :)
However when i installed the LED mat i was reading ifixits' helpful replace entire upper assembly guide which necessitate removing the display. i figured out that i didn't need to do this, but not before i loosened the six torx screws holding my display.
i retightened to a point, but when i put it all back in and fired up the lappie i see that the screen is a little bit looser than before. but then if i tighten it up too much, the shell doesnt seem to close properly. is there a simple way to re-adjust the hinge settings to their optimum place that i am missing? it doesnt seem to be a simple case of "tighten em all and it'll be fine" . or is it? and i'm just missing it?
Add a comment
1 Answer
Most Helpful Answer
If by 'looser' you mean that it is easier to open and close, there is no way to fix this, unless you replace the hinges. But loosening the six screws does not affect this at all. (Also, it may just be paranoia, you'd be surprised how we can think things are different after we take them apart)
If it is not fully connected to the main body anymore, and moving around, then yes, you just need to tighten the six screws. Best thing is to make sure that everything is lined up, then tighten until it won't anymore, don't go so tight that you strip the screws, but fully hand tight.
The easiest way to line it up is to have the display closed, loosen those screws, then use your fingers to make sure both sides of the top case and display housing are flush, as well as the front.
Score 1
Add a comment
Add your answer
Wyatt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,035
