The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
316 Questions View all
Best way to replace key cups
I’ve taken off some keys on my laptop to see which style keys my laptop has so that I can purchase replacements for worn-out keys. After noticing how dirty one was, I took off some more to clean. In doing this, one of the rubber cups making the contact and triggering the keypress was loose and came off. I was able to refit all keys successfully except the key in question. I used some super glue around the rubber cup of the key, put the cup in place and let the glue dry for a moment. I then replaced the key just as I did for the rest, except this key no longer functions when being pressed.
I’ve removed this key again and cleaned the glue as best as possible. I put the cup in place again and tested if it would trigger the keypress and it would not.
what can be done to fix this key?
Score 1
1 Comment:
I *haven’t* replaced the cup, but I’d like to. I have a replacement but am not sure how to add the new cup.
by
Add a comment
1 Answer
Drill down through the correct group and then click through the pages to the last page which has the domes MacBook Air 2011- 2017 keyboard parts
Depending on how you cleaned the Cyanoacrylate glue off you could have damaged the base at that point you’ll have no option other than replace the entire keyboard.
Use cotton swab with Acetone to take the last bit off.
Add a comment
Add your answer
Connor Smith will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 16
All Time: 446
