Why does my laptop shocks me when I am using?
There is some parts of the laptop where there is electric shock from time to time. How do i solve it?
Was the system plugged into an AC outlet? If not then you likely encountered a static shock. In the winter the air is so dry it doesn’t take much to build up a static charge so when you touch something that is conductive you can get a shock.
If you have the system plugged into the AC outlet you might have a bad outlet ground connection or the outlet is mis-wired. Go to the local hardware store and get a cheap outlet checker. These can give you a good go - no go view of your outlets power connections.
You may also have a bad charger or power cord. Make sure you are using the proper cord and it’s not damaged.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 300
