Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
What materials are needed to seal the iPad 2 front panel?
Add a comment
Most Helpful Answer
http://www.ipadscreenrepair.com/wp-conte...
this will show you where to put the pre-cut 2 sided tape for the ipad 2- very helpful! Good luck!
Score 2
Add a comment
I used 3M double sided tape from Staples and it works.
Score 1
Add a comment
If there is adhesive left from removing the front panel (assuming that is why you need to seal it?) you can reheat it using a Heat Gun until it gets sticky, then place the front panel back on.
Hope this helps!
Heat Gun Image
Product
Heat Gun
$24.99
Score 1
Add a comment
Add your answer
marcosrdz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,335
