PowerBook G4 Aluminum laptops with 17" displays. Released by Apple in 2003.
171 Questions View all
New battery charges but just makes fan run when turned on
17” PowerBook g4 with mod A1057 battery. Have run with power adapter for years with dead battery. Installed “refurbished “ battery which charged with PowerBook off but when I push the power button all that happens is the internal fan runs . This has occurred with two different batteries. Would like the portability returned.
Update (11/22/2019)
It has worked for years off the power adapter and still does. Wanting portability I purchased two batteries and they both do the same thing . I have reset the pmu and pram. For a few moments it ran on the battery once almost long enough to set the time and date, but then black screen. I noticed that the power adapter was blinking back and forth between green and orange for a moment if that means anything. I don’t know it there is a reset button anywhere.
I am wondering if there is any battery management on the battery itself or just in the computer, so I don’t know it the batteries are defective and I should return them or there is something amiss in the laptop.
1 Comment:
Does it power on using adapter?
by
Add a comment
1 Answer
Sounds more likely your PowerBooks logic board has a problem here.
Add a comment
Add your answer
Lowell Northrop will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 41
