Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
30 Questions View all
Replacing the wifi chip in my Apple TV 4
Hi,
My Apple TV 4 has a defective bluetooth/wifi chip. So I found one on eBay, a 339S00045 chip, which seems to be the same as in the ipad mini and pro. I took my apple tv apart, but the chip doesn’t seem to be that easy to replace. Is that something that is even possible at this point?
Regards,
Pieltre
Add a comment
1 Answer
Most Helpful Answer
Sadly this is a BGA chip which really needs a proper rework station to fix.
Basically, after you carefully remove the old chip you would clean the old solder off clean the board and then using a mask and the correct sized solder balls layout the field and then reflow the chip back on.
Given the cost of the needed equipment and sundries. I think it will be cheaper just getting a new Apple TV ;-{
Score 1
Add a comment
Add your answer
Jean Maxime Lachance will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 541
