Model A1106 / 1280x854 screen resolution
90 Questions View all
Charger orange light, battery doesn't charge, PB doesn't turn on
Not sure how many people are around to help with an issue like this, but here it goes...
Got a PB 15" 1.5Ghz a while ago with these symptoms. I tried replacing the DC-In board and no luck, and I'm 90% sure I tried a different charger.
Now I've just noticed that it's got DDR2 533 mhz RAM when it should have DDR 333, I don't have any of this to try so I tried taking them out and booting up, it should beep at me, right? Anyway the light is still orange on the charger.
Reset PMU, taken out battery (which is a cheap knockoff), my next bet is to replace the motherboard.
Any suggestions before I do this?
Any help greatly appreciated.
Add a comment
1 Answer
Chosen Solution
Before spending the money for a new logic board try just one stick of the correct RAM. You said you got it "with these symptoms", and listed no symptoms. You have a power supply that you don't know if it works and a knock off battery that you don't know works. RAM that you don't know works and you want to replace the logic board? You have to many variables to isolate a problem. Please tell us the symptoms before and after you replaced the DC-IN board.
Score 2
Add a comment
Add your answer
spacec0w will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 14
All Time: 868
