The Canon EOS Rebel T5, also known as the EOS 1200D, is an 18MP DSLR camera released in February 2014.
32 Questions View all
5d mkii CF Card Format Error
Recently one of my pins bent in the CF reader of my 5d mkii. I got it repaired but now when I first insert the card it says “ Card ++https://elecpay.in/tneb/++ not formatted. Format card with this camera.” Then once I press format, it says “ cannot format. Change card” I used a different card and it worked like normal. I thought it might be the CF card I was using, but when I plugged it into my computer with my card reader, I could still view all my files. I have magic lantern installed and the card is a Lexar Pro 1066x 128gb card. Any ideas on how to fix this?
https://myip.kim/ ++https://birthdaywishes.onl/++
Score 1
Add a comment
Give this formate a try SD Memory Card Formatter it often fixes things. Its also possible the SD card is damaged or just worn out.
Add a comment
c f card not format format with camera canon camera mark ii
Add a comment
I had a Canon camera that used a CF card, one of the pins got bent, and it gave me a similar problem. I used a wire wrap tool (Basically a very thin tube that fitted over the pin) to pull the pins straight.
Suggest you look closely at the pins they should all be at the same pitch and not bent. Also it is possible when putting the CF card in, to push a pin inwards, so check that all the pins are the same length and that there are none broken off. If there is any discrepancy, I suggest returning it to who ever repaired it.
I also suggest that you only remove the CF card when absolutely necessary. You can connect the camera to the computer to download files rather than take the CF out.
Add a comment
Add your answer
ElvisFernandes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 29
All Time: 789
